A11 question
Discussion in 'Blu-ray & DVD Players & Recorders' started by jdg, Jul 10, 2004.
  1. jdg
    jdg
    Is it possible to run progressive scan over component and rgb over scart at the same time ?? (when connected to two different screens)
  2. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    No, dont think so
    But youll just have to try it, and hope
  3. jdg
    jdg
    Problem is, I dont have two screens yet. Anyone that could try it out?
  4. ailean
    ailean
    What I've noticed is you can do;
    RGB
    Component I
    DVI I
    or
    RGB
    Component P
    or
    RGB
    DVI P
    So as far as I can tell RGB scart is always active but Component and DVI are mutally excusive when Progresive Scan is active.
