A/Z Streets On PDA ?
Discussion in 'Mobile Phones Forum' started by lurcher, Jul 5, 2004.
  1. lurcher
    lurcher
    May 15, 2003
    4,220
    Stalybridge
    +221
    Know you can get A/Z of Greater Manchester on CD rom, any one know if they are available on SD cards for palm pda or can you transfer to memory card from cd. Looked to be about 120 mb of info on the advertised cd.
    Anyone got street maps on their pda ?
    TIA
  2. BaggieBoy
    BaggieBoy
    May 3, 2004
    38
    I have a SatNav package (Kirrio) which has street maps for the whole of the UK on a Palm Tungsten E. It may be overkill for what you want however. See:
    http://www.kirrio.com/uk/index.php
  3. lurcher
    lurcher
    May 15, 2003
    4,220
    Stalybridge
    +221
    Baggieboy,
    Thanks for that, was condsidering a sat nav package for my T3 so will look at it.
  4. BaggieBoy
    BaggieBoy
    May 3, 2004
    38
    The only problem you might find is getting a SatNav package that doesn't have an included PDA. The Kirrio one is available but I've only seen it as a complete package.
