A wii problem.
Discussion in 'Nintendo Wii-U & 3DS' started by unleashedmaniac, Dec 23, 2006.
  1. unleashedmaniac
    unleashedmaniac
    Feb 24, 2006
    481
    +12
    Okay, this may be a really simple thing that i'm missing but here it goes.
    I've started up my wii, synced the controller but basically everytime i exit a menu the controller basically disconnects itself. Just another quickie, when i turn off the console. It seems i need to resync everytime i start up again. Is there anyway of keeping it synced, so that i can turn on the console using the remote etc?
    All help appreciated.
  2. nickp8
    nickp8
    Feb 16, 2005
    1,742
    West London
    +144
  3. unleashedmaniac
    unleashedmaniac
    Feb 24, 2006
    481
    +12
    Afraid i've tried that already:(
  4. unleashedmaniac
    unleashedmaniac
    Feb 24, 2006
    481
    +12
    Also once i lose the sync, i have no lights at all on my remote. I even changed the batteries.
  5. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    With the wii turned off,
    the remote should give you 4 lights with every button press
  6. mwatson800
    mwatson800
    Oct 16, 2002
    361
    Farnborough
    +15
    Correction, every button press shows the battery level of the controller when the console is switched off.
  7. unleashedmaniac
    unleashedmaniac
    Feb 24, 2006
    481
    +12
    See i'm not getting anything when the console is turned off.
  8. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    If it's not dead batteries, then it must be a dead controller :thumbsdow
    Looks like you need to get a wii play or remote from somewhere before the shops shut,
    That's not going to be fun :eek:
  9. unleashedmaniac
    unleashedmaniac
    Feb 24, 2006
    481
    +12
    It's just weird because if i press the sync button it flashes etc but just cuts out.
  10. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    You are pressing the sync button on the console and remote? (under battery cover)
  11. unleashedmaniac
    unleashedmaniac
    Feb 24, 2006
    481
    +12
    Yep.
  12. burnsybhoy
    burnsybhoy
    Jan 18, 2004
    724
    South Ayrshire
    +39
    I got mine yesterday and was playing it last night with my mates for a while and I got up this morning to have a quick game of bowling and not I can get my remotes working..whenever I press a butoon on them all 4 lights flash but nothing..I've tried the method above and also the same in the thread thats linked above and still having no luck..I know its not broken its just being awkward!!
  13. dr no
    dr no
    Mar 30, 2004
    12,784
    +7,244
    try switching the console off at the plug point and restart. I had same prob and this appeared to solve it.
  14. burnsybhoy
    burnsybhoy
    Jan 18, 2004
    724
    South Ayrshire
    +39
    jut upluged for 10secs and booted it p again an still nothing. I've tried holding both sync buttons down, then just either sync button and nada!!..
    I hope there's a fix for this is a forthoming update..It's a bit f a pain if u goota do it everytime!
  15. wellladida
    wellladida
    Dec 27, 2005
    2,687
    Jail cell 21236-386489
    +203
    Im a bit confused if it was the remote that came with the wii there was no need to sync
  16. burnsybhoy
    burnsybhoy
    Jan 18, 2004
    724
    South Ayrshire
    +39
    I know I've got two remotes..(I got one with Wii Play and now I don't know which one is which..now thats confusing!
