A wealth of information on the web...
Discussion in 'Satellite TV, Sky TV & FreeSat' started by damienb, Jul 13, 2001.
  1. damienb
    damienb
    Apr 5, 2001
    28
    UK
    Hi there,
    Just investigating some more satellite info and came accross this superb web site, loads of information, they install good Dig boxes (latest Panny), I just wish they where in Liverpool. :(
    Anyone else got useful satellite info/installation sites, post them here, esp. if you know any good installers in Liverpool.
    Regards,
    Damien ;)
  2. Darren_L
    Darren_L
    Jun 30, 2001
    96
    England
    +3
    Don't know if they install in your area but have a look at Aerial Systems They use Pansonic boxes. No I don't work for them ;)
  3. Eric Chadwick
    Eric Chadwick
    Aug 10, 2001
    22
    P&A audio in crosby have been helpful to me. They do the panasonic digiboxes.
    Then again do you really want a panasonic digibox - mine worked fine for 2 years but since sky have changed the software I am now suffering the constant crashes problem. One box has been replaced (cost £80) but now its replacement has developed the same problem. For a while not using the number keys to change channel (as suggested on this forum) did work but now it is completely kyboshed again <img src="rolleyes.gif" border="0"> <img src="mad.gif" border="0">
