A way to unlock Sound level in Sony NWZ-F805?
Discussion in 'Headphones, Earphones & Portable Music' started by GokuSS4, Mar 19, 2013.
  1. GokuSS4
    GokuSS4
    Dec 31, 2011
    2,730
    87
    London
    +167
    Hi all,
    I got this player a little while ago, even though it is loud I find that with earphones I need to get a little higher and am wondering if there is a secret menu with this player? It's the one with Android 4.0.
    Also is it upgradeable to the latest Android? I haven't received any updates for it so just wondering.
  2. FredBare
    FredBare
    Dec 2, 2008
    370
    England
    +39
    there is no way to unlock Sony's Euro-volume cap (UK & Euro models), the only way around it is to buy a Japan, USA or Asian model.
    the update is for ICS, you have to go to the region that your Sony is from, UK & Euro updates have different links... go to the Sony helpdesk for advice they should provide you with links.
