A Very Stupid Question
Discussion in 'Movie Forum' started by Arshad, Nov 6, 2003.
  1. Arshad
    Arshad
    Usually DVDs we buy from the store are in what format? I mean these DVDs are interlace or progressive? Are there any 480p DVDs or 720p DVDs?
    How about HD-DVDs that are going to be available, will they be compatible with the current plasma tv sets?
    I understand that you can make a 720p dvd on a computer, can't you?
    The reason I'm asking is the Philips E box only accept interlace signal such as 480i and 576i.
    Can anyone explain to me please. Sorry for being so ignorant.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I THINK what I'm saying here is right. :)
    DVDs are either NTSC or PAL, meaning 480i or 576i as the MPEG decoder outputs them, something else is needed to convert then into progressive, either the DVD player itself, a dedicated convertor such as a de-interlacer, or an HTPC.
    HD-DVDs are 1080i I think, if plugged into a lower-resolution display like a plasma or pj the display will down-convert as necessary .. just as happens if you plug a normal PC into it without specially setting up a compatible resolution.
