TwistedPear
Can anyone recommend an upgrade for my A/V receiver?
My current setup in primarily (90% of usage time) Home Cinema. I have Sky, Xbox and an Arcam DV88, connected to a Sim2 HT200, through a Sony STR-DB940 and an iScan Pro. The Sony also drives a 5.1 Mission FS2 speaker package.
The A/V Receiver is probably the first item I'm upgrading, and may move onto a new projector, and HiFi speakers at a later stage (currently very happy with the DV88).
The reason I'm starting with the Amp is because I use my Xbox with Component outputs, and would like component switching (as well as S-Video) in the amp (currently I have to unplug and plug devices from the iScan Pro that feeds the Sim2).
So, what decent quality (i.e. will fit well with the DV88) Receivers are there out there? It's been a while since I looked at the market, so hope you folks can help fast track my search.
Budget is flexible but would hurt if it got more than say £600.
Thanks in advance
Mike
Thanks in advance
Mike
