A/V In Connection
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Widescreen Wiz, Apr 13, 2005.
  1. Widescreen Wiz
    Widescreen Wiz
    I have a Canon MV850i which comes supplied with a 4-pole A/V-In cable. The problem I have is that I need one with a 90 degree bend on it so that when inserted, the plug stays almost flat against the body of the camcorder - the one supplied goes straight out.
    Having looked at the Maplin catalogue, there seems to be 2 available variants - one for Sony and one for Panasonic - which have different positions on the pin for ground, audio and video.
    Does anyone know which one would work with Canon?
    Thanks.
  2. Brian110507
    Brian110507
    Don't know - but havent you got some form of continuity tester - even a battery and a torch bulb so that you could very quickly check out the connections of your supplied lead - then you'd know exactly what to get.
  3. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Best place to try for this type of cable is www.keene.co.uk if they don't stock it they can make it for you.
    DigiStuff
  4. Brian110507
    Brian110507
    Yes but Keene also stock both types - so you still need to know which one you want
  5. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Good point! Call them and ask !!
    DigiStuff
