A/V in and out on Sony Camcorders
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by lurcher, Sep 5, 2005.
  1. lurcher
    lurcher
    May 15, 2003
    4,105
    Stalybridge
    +198
    Any one with a Sony that has a/v i/o can explain to me how the sytem works and with what cables/remote signals.
    I am trying to acheive the following,
    Record to a/v in from bullet camera then replay from a/v out to monitor. Any lead swopping involved ? Is there one port for both signals ? Is it just commands from a remote ?
    NB. Not got this equipment yet.
  2. Roy Mallard
    Roy Mallard
    It's one port, depending on the model of cam you go for:
    cosumer: Y/C & composite (using S-Video port & phono port, sometimes on a 3.5 mini jack lead)
    pro: Component, Y/C & Composite (using either BNC or phono & S-Video)
    You record in VCR mode not Camera mode, so make sure that your bullet cam gives a LINE level audio out.
    You can remote record via infrared & sometimes LANC remote, depends on exact model of cam & controller
  3. lurcher
    lurcher
    May 15, 2003
    4,105
    Stalybridge
    +198
    Roy ,
    Thanks for the quick response. Prob something along the lines of the HC32E I was thinking of.
    So I would have to remove av in lead and replace with av out to monitor to instantly review footage ?
  4. Roy Mallard
    Roy Mallard
    fraid so, it can only be input or output at one time, not both.
