A/V Cabling & Connections
Discussion in 'Home Cinema Building DIY' started by looie, Jun 2, 2003.
  1. looie
    looie
    I am doing the following:
    1. Connecting my DVD to a video source selector box.
    2. Connecting my VCR to a video source selector box.
    3. Connecting my video source selector box output to my satellite s-video input (s-video TV in).
    All connectors would be s-video connectors.
    My questions is: Do I have to connect any other cables (the Red, White and Yellow component cables, for instance) in order to get both video and audio feeds? Would my resolution improve if I did connected both s-video AND component vidoe cables instead of just the s-video cable?
    Thanks, John
  2. GodtheDJ
    GodtheDJ
    S-video signals only carry video signals (no audio), so yes you would need other cables to acheive this.
  3. looie
    looie
    Thanks, GDJ. I now understand that I can also use component cabling (R,Y,W combo cable as a feed for both audio and video. Yes?
  4. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    That's right, but you would then be using composite video, which is not as good a s-video. For the case you mention the best solution is s-video and phono cables for the audio.
  5. looie
    looie
    Thanks, folks, for the very timely help. I appreciate it. I hope i might return the favor one day.
    John
