A/V amps....how hot does yours get.
Discussion in 'AV Receivers & Amplifiers' started by paulr, Aug 5, 2002.
  1. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    I have a Denon 2802,...just wondered how hot yours gets and how much clearance you give it?
    Paul..
  2. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,487
    Got a Denon as well and it can get fairly hot, got about 6 inches space above and 3-4 inches at the sides. The front pokes a few inches out in front of the shelf above though, so there´s nothing above that bit of the amp.:)
  3. Spanglemaker
    Spanglemaker
    Jul 4, 2002
    76
    +10
    I have a 3802 and have 6 inches clearance at the sides and just over an inch above. Clear at the back (and front).
    I did wonder whether this would be enough as the manual specified about 4 inches, but it doesn't get anything other than 'warm'. Guess the fact that it's clear front and back helps the ventialtion a lot rather than being enclosed.
    Cheers.
  4. Doug
    Doug
    Hi, got the 3802 as well and it got so hot at high volume levels that it actually heated up the glass rack 1 inch above it too! I have now moved it to the top of the rack and it's much better.
  5. KevB_UK
    KevB_UK
    Read the manual and find out how much room your supposed to give it, then add a bit extra!
  6. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    I can fry an egg on mine...
  7. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    ok..thanks....i think the answer is .....HOT!!!!!!!!!!!!!:D
  8. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    I own a Denon 1802, it does not get hot I have it at the top of my stand so it has full air clearence to edges of my room.
    The only time it did get hot was a few days ago when the temp was in the 32-33 C area and the ambient temp in my room was quite high.
    Amps do get hot (esspessially when run at close to full tilt for a long period of time) but if they are well ventalated then they are ok.
  9. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    My manual recommend 10 cm clearance.......the stand i've just bought will give it 8cm......if it gets too hot i'll put it on top,but i'd rather not.
    I'll monitor the situation.
  10. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Yamaha DSP-A1 on top of the rack with clearance all around. Handwarm only, even when driven hard.
  11. Spanglemaker
    Spanglemaker
    Jul 4, 2002
    76
    +10
    Just to share something I noticed last night which could reduce the heat from the amp.....
    My 3802 is fed from the TV phono outputs. I was in the TV setup menu and noticed that the phono-out volume was only at about 50-60%. I cranked it up to about 90% of max and now I can run the 3802 at a much lower level for the same volume, and therefore less heat......
    Chris.
