Quantcast
A/V Amplifier
nasxxx
Have a choice of the following A/V amps :-
Yamaha dsp-ax757se AV amp. or a Pioneer VSX-D812 AV amp.
Which is better the Yami or Pioneer ? I am a newbee to home cinema I know both units are kinda old by todays standards but what one is best. ???
nasxxx
Found the spec for the Yama amp below that the Pioneer, still not too sure which is better also what is the difference between neo 6 and Cinema DSP any help on which of these two amps to get I would apreachite.
7.1-Channel Digital Home Cinema Amplifier
Top-class 7.1-channel amplifier delivering 700W of sound power and superb picture quality, as well as outstanding features like YPAO, Quad-Field CINEMA DSP and Night Listening Enhancer. The unit has also been specifically tuned for the UK to provide audiophile stereo reproduction.
The DSP-AX757SE has the following Main Features:
High Sound Quality
7-Channel 700W Powerful Surround Sound (100W x 7 DIN)
Digital ToP-ART and High Current Amplification
Pure Direct Switch for High Quality 2-Channel and Multi-Channel Sound Reproduction
192 kHz/24-Bit DACs for All Channels
Specifically Tuned for the UK to provide high quality 2 channel reproduction
Surround Realism
Dialogue Lift for Enhanced Dialogue Sound Output
Quad-Field CINEMA DSP and 14 Surround Programmes
Night Listening Enhancer (Cinema/Music) and SILENT CINEMA
Audio Delay for Adjusting Lip-Sync (0â€"160ms)
Easy to Use
YPAO for Automatically Optimizing the Sound in Your Room
Learning-Capable Remote Control Unit with LCD Indication
On-Screen Display
High Picture Quality
Full Component Video Up Conversion
HDTV (720p/1080i) Compatibility
Wide-Range Video Bandwidth (60MHz -3 dB)
Pioneer spec in below link
VSX-D812-K (Archived) - Pioneer Europe
nasxxx
Yamaha dsp-ax757se AV amp. or a Pioneer VSX-D812 AV amp. ^^^^^^^^^^ Anyone can tell me please which one is better ?
eaglemmoomin
No idea.
Probably be safer with the Yamaha.
nasxxx
ok thanks will use the Yamaha then for the cinema system and the Pioneer for the PC system.. I know both of these units are dated but think the DSP on the Yamaha might perform better than the Pioneer Neo 6. Or would someone recommend just buying a new modern unit which has HDMI inputs and better sound processing ...
Similar threads
