A/V amp with lip sync delay
Discussion in 'AV Receivers & Amplifiers' started by taimur, Jan 17, 2003.
  1. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    I'm about to buy a DVD/ amp/ speaker combination and I still haven't decided which to buy.
    One thing that would really annoy me, though, is if there were lip sync problems with a DVD, so the facility to delay the video or sound to correct this is a must for me. I could not possibly watch a film where there were any lip sync problems - it would really just ruin the experience for me. I saw a demo of a huge and great sounding home cinema system, but because there were lip sync problems, I just couldn't appreciate the whole experience.
    Can anyone tell me if the following amps/ DVD players have this facility:
    Arcam DV88 DVD player
    Arcam AVR200 amp
    Rotel RSX 1055 amp
    Denon AVC-A11SR amp
    Denon AVR-3802 amp
    Taimur
  2. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    The Audio Delay feature will be found in the amp not usually the dvd player.
    The Denon A11SR & 3802 do not have this feature neither does the Arcam AVR200. Only one I don´t know about is the Rotel.
    Amps that have the feature are the upgraded Denon A1SE, A1SR, and the new 3803, as do processors like the Arcam AV8. A couple of the Onkyo receivers have the feature as well I believe.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    The problem with lip sync is due to the video being "delayed" due to video processing for Progressive Scan / Line Doubling / etc.
    No DVD player (that I know of) has the facility to delay the audio to correct for this. Also the only one of the amps you've listed which MAY have a global delay is the Denon A11SR but you would have to check the specs / manual as I'm not sure. If you can hold on, the new Denon 3803 does have a global delay for correcting lipsync.
    Victoria
  4. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    The Rotel doesn't have this ... between us we've answered well cause I wasn't sure about the A11SR :)
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    High Wycombe, Bucks, UK
    +59
    The Arcam DV88P and DV27 have a digital audio delay built in that you can turn on if you so wish to keep the picture and sound in sync.
    Not sure if it's on the new DV88+/89 though as I've not had hands-on experience with this yet.
  6. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Oh well ... thats another foot I've put in it today!!
    On a slightly different track ... is it possible that the delays in processing on a 100Hz (CRT) TV are sufficient to cause lip-sync problems?
    Victoria
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    +59
    Quite possibly, especially if it's done digital (which I guess it is), as there will be a time delay for the digital to analogue conversion and back again.
    We always ran the DV27's at work with the progressive delay on, because any processing in the Pioneer plasmas would add a video delay, even if not using the progressive output from the DV27.
  8. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    taimur
    are you using prog scan for your video sources? as previously mentioned the prog scan processing delays the video causing sound sync problems. If you are not using prog scan don't worry, it won't be a problem.
  9. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    actually I haven't bought anything yet - I'm just in the process of saving up. I think I'll save up and audition something like the Denon 3803 with audio delay. I'm sure I couldn't hack a lip sync problem, and it's good to have as much information as possible before spending a considerable amount on hardware.
    Thanks for all the answers
  10. John-D
    John-D
    Does the new Philips 963SA DVD player have the audio delay feature?
    John
  11. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    If an amp is acting as a switch for all video inputs, does that also eliminate the lip sync problem, if progressive sacn component output is being used?
    Taimur
  12. James45
    James45
    Sep 21, 2002
    2,844
    59
    i doubt there is any form of auto synchronisation or that the sound or video signals interact at all. All synchronisation will be manually done
  13. Jase
    Jase
    Mar 16, 2001
    9,536
    UK
    +937
    No, you still need an amp/receiver/processor with the Master Audio Delay feature.
  14. infomatique
    infomatique
    The Denon A1SR has the feature that you require and as far as I remember the most expensive ONKYO (can't remember the model number) also has this feature.
    I have the A1SR and the audio delay control resolves the lip sync problem which was introduced by the I-SCAN line doubler.
  15. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    I see that the Pioneer DSX 2011 also has audio delay features (for about £900). I recently read some good reviews of it. Has anyone heard the amp to say how good it is?
  16. themmings
    themmings
    Nov 21, 2002
    380
    Northampton
    +4
    Hi taimur,
    The Poineer 2011 does not have audio delay.
    I was after this amp, but dropped it off the list beacause of this. I'm currently waiting for the 3803 which does.
    Tim:)
  17. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
  18. infomatique
    infomatique
    Are you sure that it is "Audio Delay" used to compensate for lip sync problems rather than channel delay used for speaker setup.
  19. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    like you say, I think it's a setup feature not a lip sync feature
    Taimur
