a.t.i.radeon 9250 256mb gfx
B
bigdavie0
:hiya: would mce support a radeon 9250 gfx card,i have an hauppauge pvr150 mce tuner,just wondering will this do or will i have to purchase a new one,if so what one, my mobo has 1 agp slot and 5 pci
I don;t think it is listed as a supported card i medai center, it might work for some thing but may lock up when you launch the meda center application, best gettign a medi center certified card...like a radeon x700
Link
S
Skunkpipe
Yes it'll work no problems.
S
Skunkpipe
CyBeRkId2002
i have the card and although it does work its not ideal... had a lot of trouble getting dvds to run smoothly without stutter and i have tried every setting possible!
deksawyer
I used to use a 9200 and it worked well.............
D.
S
Skunkpipe
I doubt very much that's an issue with the card; more likely a refresh rate not being set corretly or some other h/w bottleneck
Trending threads
