A Stupid Question from a Total Idiot.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Simon44, May 31, 2005.
  1. Simon44
    Simon44
    Have just bought a new Sony VTXD800 Digibox to go with my new Hitachi 32LD7200. Would there be anybody out there that could enlighten me to how to run through RGB Scart.
    Bought the bloody thing cos it has RGB and don't know how to use it, please help.
    Simon
  2. dvdsubtitles
    dvdsubtitles
    :rtfm: read the manual???
  3. Simon44
    Simon44
    Thanks for your help.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    It was good advice but not always clear if it's given with a sarcastic overtone:)
    The TV scart on the SONY has RGB output, the menu will have the option to select which format you want it to output (RGB, Composite or s-video).
    I don't have this SONY so can't tell you exactly where to look and there are no guides on the website.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    I do, but am at work so can't help 'till I get home.
    If nobody else has walked you through the setup by tonight (and I remember before I head off down the pub :D ) then I'll have a play through the menu and see if I can help.
    From what I remember of the setup though it was very easy to work out. Just go into the menu and go through untill you see the picture settings. As long as you have a good(ish) quality scart lead and the Sony is set to output RGB then it should be as required. Just make sure the scart on the TV is also RGB compatable.
    Mark.
  6. mrtbag
    mrtbag
    Dec 17, 2002
    3,509
    Anywhere I want
    +394
    The following should work.
    Select Menu
    Select Picture
    Select TV Output
    Select RGB
  7. Simon44
    Simon44
    Thank you for helping me. I bought the Digibox yesterday and plugged it in and went out for the night, came back to find my wife had cleared up and thrown the manual which was on the chair, I would have read it.
    Probably not the best question to put on here but you live and learn eh!
    Thanks again guys.
  8. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    One little thing; probably obvious; I think this box has two scarts and only one of them outputs RGB so make sure the right one is connected.
    Richard
  9. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Another point you may miss is that you only need to connect the vcr scart out of the 800 to the vcr. You dont need to run a scart from the vcr to the tv.
