Well, a couple of things,
1. My TV supports 1080p over component and only 720p via VGA.
2. As far as Im aware you can't upscale DVDs over component, only VGA.
I have a cooler king (attatched below). As you can see, this splits out all the connections in to standard connectors with two switches to select what type of connection your using.
I have been considering getting a VGA to component cable, plugging the component end in to the TV and the VGA end in to the xbox, this way I can keep the 1080p resolution but does this also mean I will be able to play DVDs upscale to 1080p as technically the xbox is outputting over a VGA connection?
Thanks for any input in advance
