A Solar Solution
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by richard_hawkes, Jan 6, 2005.
  1. richard_hawkes
    richard_hawkes
    Hi there,
    I have a friend who will be travelling to Uganda/Kenya shortly, and was wondering how easy it would be to set up a solar charging scenario, using this solar panel and a charger like this.
    Am I way off the mark here, or do you guys think this is a viable option. I don't know much about miliamps or watts! Just know there won't be many plugs in the jungle!
    Hope you can help
    Richard
  2. El Indio
    El Indio
    Jan 1, 2003
    35
    Hi!
    What you need to find out is whether lithium ion batteries can be trickle charged over an extended period (like Ni-Cads). Given that a camcorder battery is large (in energy rating), its gonna take along time to charge up.
    To give you an idea, my battery charger has an output of approx 8V * 1A = 8Watts. This would require 4 (of your suggested) solar panels, or take at least 4 times longer with one (assuming its possible to trickle charge and optimal sunny conditions)
    Sadly, It doesnt sound too hopeful to me, but then Im NOT an expert on charging.
    El
  3. richard_hawkes
    richard_hawkes
    Thanks El Indio, that sounds like a start. You can connect those sport panels together, so maybe two panels would be acceptable, bearing in mind it would take twice as long to charge. Starting to get pricey though.
    Any other suggestions? Anyone?
    Thanks again
    Richard
