A Small Centre Speaker
Discussion in 'Home Cinema Speakers' started by johndickinson, Jun 26, 2003.
  1. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    When I say small I mean the height must be less than 120mm, the width and depth are not issues.
    Has anyone seen small speakers and if so where?
    Many thanks
    John
  2. jhjerpe
    jhjerpe
    Mar 1, 2003
    696
    2
    28
    North London
    +63
    If you are on a smallish budget something like the B&W VM1s are good, £125 RRP . What sort of price bracket where you looking at?
  3. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    Budget of around £300.00
    Currently have a Wharfdale one, but his is 150mm and the AV stand that I am looking at getting will allow for a 120mm speaker.
  4. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    According to B&W's site, the VM1 is 124mm wide. Amazingly, the bass driver is 125mm wide! Presumably using technology from their high-end Tardis range.
    D.
  5. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    :rotfl:
  6. stranger
    stranger
    May 29, 2003
    2,032
    5
    117
    Manchester
    +705
    richer sounds are doing a Lynn ( I think Centric) for around £120.00.
  7. nathan_silly
    nathan_silly
    You mean a linn centrik.
    Pretty hefty centre, 4 Ohm, and quite low sensisity at 88dB. Better have a decent amp for it.
  8. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    Thanks stranger - already looked that one up Richer site says 130mm, although the picture makes it look quite thin
  9. stranger
    stranger
    May 29, 2003
    2,032
    5
    117
    Manchester
    +705
    yes-Lynn was a girl I fancied
    jd sorry about the size-some days I can't get anything right:confused:
  10. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    Thanks all for your suggestions - may have to rethink the stand.
  11. jhjerpe
    jhjerpe
    Mar 1, 2003
    696
    2
    28
    North London
    +63
    I did own a Bose centre speaker, very slim.... but wouldn't recomend it.... uccch
  12. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    At the weekend I saw a thin sony centre speaker - I think it comes with the DAV888 package - does anyone know firstly if
    1 These can be bought individually (without the rest of the package)
    2 If it's any good?
    John
  13. banners
    banners
    Jun 26, 2002
    439
    nottingham
    +16
    John, have you thought of diy-ing your Wharfedale? Dunno about your cone sizes, but if they're small enough!
    Just an idea
    cheers steve
  14. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    Thanks Steve - I have thought of this, had a look around at box enclosure sizes.
    This would probably be a last resort. Have you done any diy speakers yourself?
  15. patr1ck
    patr1ck
    Jun 29, 2002
    247
    Manchester
    +26
  16. johndickinson
    johndickinson
    Jan 9, 2003
    369
    28
    +25
    Cheers Pat
    That would fit very nicely
