a simple question
J
jimboh
hello,
my sky+ box is knackered - it keeps jumping random recordings, and is just over a year old.
if i purchase a nw sky+ box from the web, do i need to contact sky?
Is it a simple as just replacing the box and fitting the leads at the back, or does sky need to configur or reset the new box?
thanks for you time:smashin:
FRANTIC FRANC
Better to try replacing the hard drive first as You never know what you'll end up with second hand. Also a chance to expand the recording time!
Cheers, Franc
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
