"A Runtime error has occurred, do you wish to De-bug?"
Discussion in 'Desktop & Laptop Computers Forum' started by the_sanguine, Dec 26, 2004.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I keep getting a pop up window with this on it when surfing the internet. Particularly on Ebay.
    Does anybody know what it means and how to overcome it?
  2. Crocodile
    Crocodile
    Nov 4, 2002
    15,437
    +4,666
    You haven't said which OS or browser you're using which makes it kind of difficult. If XP with MS IE, try this:
    1. Start Internet Explorer.
    2. On the Tools menu, click Internet Options.
    3. In the Internet Options dialog box, click Advanced.
    4. Click to select the Disable script debugging check box.
    5. Click to clear the Display a notification about every script error check box.
    6. Click OK.
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    Thanks. Your assumptions are correct. Done that. I'll see how it goes
