A quick question regarding bi-wiring
Discussion in 'AV Receivers & Amplifiers' started by hi_robb, Nov 20, 2004.
  1. hi_robb
    hi_robb
    hi folks,
    Quick question regarding my AVR200 and bi-wiring. Is it possible to do so on the AVR200. It's only a 5.1 amp so only has 1 set of speaker terminals on the amp for left and 1 for right.
    My speakers (Monitor Audio silver 8) has 2 sets of terminals for bi-wiring or bi-amping. Can I run 2 sets of cable from the speakers to the 1 set of terminals on the amp? and finally is it likely to make a difference doing so?
    Need a quick answer as I'm off out for some cable in a little while.
    Tia
    DAve
  2. recruit
    recruit
    Robb yes you can and it will improve the sound your speakers were designed to be Bi Wired so make use of it! ;)
    John
