A Quick Denon 3802 Question.
Discussion in 'AV Receivers & Amplifiers' started by BarryK, Feb 5, 2003.
Tags:
  1. BarryK
    BarryK
    Nov 18, 2001
    93
    I have the above amplifier and i just wanted to check that i can connect the speaker outputs of my old kenwood pro-logic amp into the `ext-in` connections of the 3802 in order to use the same set of speakers.
    I think it says in the 3802 manual that this is possible as anything connected to the `ext-in` connections bypasses the 3802 circuitry and ouputs directly to the speakers.
    Just thought I`d check on here incase I damage the 3802.
    Cheers,
    Barry
  2. Jase
    Jase
    Mar 16, 2001
    9,538
    UK
    +938
    The EXT-IN is for external decoders/processors. You feed it a Pre-Amp signal not one that has been amplified already. The EXT IN bypasses the Denons pre-amp section and goes directly to its amplifier section then the speakers.
    Why do you want to use the Kenwood Pro-Logic amp? The Denons own pre-amp section is likely to be superior anyway.
  3. Jase
    Jase
    Mar 16, 2001
    9,538
    UK
    +938
    Yes you would if the signal has already been amplified by your Kenwood.:(
  4. BarryK
    BarryK
    Nov 18, 2001
    93
    The problem I have is that my old kenwood unit has cd/tape decks/turntable etc. but they are all connected together using a ribbon cable and have no phono connections on them, so i was wondering if I connected the speaker output of the amp. to the 3801`s `ext-in` I would then be able to get rid of the kenwoods speakers and still use the cd/tape/turntable.
    Would this damage the 3802 though????
    Barry
  5. Jase
    Jase
    Mar 16, 2001
    9,538
    UK
    +938
    Does the Kenwood have any analogue audio outputs at all? If not, then you won´t be able to plug it into the Denon.
  6. BarryK
    BarryK
    Nov 18, 2001
    93
    No, it has no audio outputs at all. Not possible then??????
    Barry
  7. Jase
    Jase
    Mar 16, 2001
    9,538
    UK
    +938
    Nope, I´m afraid not.
