A question to KDEP37XS1 owners
Discussion in 'Plasma TVs Forum' started by Maximus5, Aug 7, 2005.
  1. Maximus5
    Maximus5
    May 23, 2004
    33
    Hi to all happy KDEP37XS1 owners.
    I have this wonderful plasma for a couple o months now and I'm generally extremely satisfied with everything, especially with the picture quality.
    There is doe a slight detail in the screen that I haven’t pay attention so far. Since I returned from my holidays I’ve noticed that when full screen there are couple of lines missing on the top (8 mm) and on the bottom (4 mm) from the screen edge. Now I wonder, is this normal?
    I can see the cell rows in plasma but they are off.
    Can some of the KDEP37XS1 owners check this and report here; just to be sure everything is OK with my set.
    Many thanks
  2. stu954
    stu954
    Is it with all sources? Mine fills the screen with dvd and freeview but with the ps2 there tends to be some gaps.
  3. Maximus5
    Maximus5
    May 23, 2004
    33
    The gap on the top and bottom is regardless of the source the same. On the far left I can see probably the ALIS's common electrodes, so on the top there are first 4 elektrodes (probably 8 lines) missing (off) and on the bottom 3 (6 lines).
    I'm starting to be worried about this.
    Any ideas, how about others?
    And thanks stu954 for your feedback.
  4. Maximus5
    Maximus5
    May 23, 2004
    33
    Come on. Where are all SONY KDEP37XS1 owners?
    Please just check if the full screen lives no gaps on the top and the bottom of he screen.
    :lease:
