A Question of power handling for speakers connected to an amp....
Discussion in 'Home Cinema Speakers' started by Matt_C, Jan 1, 2007.
  1. Matt_C
    Matt_C
    Aug 14, 2005
    9,842
    Essex
    +1,831
    Right, so here's the scenario.
    My AV amp kicks out 100w per channel and I am considering a pair of Mission dipole speakers for the rear surrounds.
    Thing is, these Missions state a power handling of 25-75w - will my amp destroy these?
    I probably won't have it up silly loud too many times - will be in a new house with new neighbours and fairly thin walls methinks lol... But, is sticking a pair of 75w capable speakers on a 100w amp gonna overamp them enough to do any damage?
  2. the mechanic
    the mechanic
    Nov 30, 2003
    1,232
    Wrexham,North Wales
    +53
  3. rszee
    rszee
    May 7, 2005
    194
    Kent
    +44
    Your more likely to damage speakers with an under powered amplifier.
    Your amplifier is fine.
  4. Nimby
    Nimby
    Jan 27, 2004
    9,206
    The Danish Bacon Factory
    +671
    If all AV receivers actually put out their claimed wattage with all channels driven then you could at least be assured that your speakers would be getting a nice clean signal.
    But they don't. So they won't. ;)
  5. Matt_C
    Matt_C
    Aug 14, 2005
    9,842
    Essex
    +1,831
    Thanks guys - certainly did put me mind at rest :)
    I am usually an advocate of over amping things generally - nothing like a bit of headroom to make speakers sound good! - but thats for live situations and car audio, where I can stick a 100w speaker on a 150w amp and then just reduce the gain somewhat to not over power it. But I don't know how to do that with this home cinema malarky, hence the post! :)
  6. miceri
    miceri
    Apr 8, 2006
    1,048
    Stockholm
    +59
    I've heard this many times now. Question is, how can too little power damage the speakers?
    What is the difference between under-powered amp feeding speakers, or simply having the amp turned down really low.
    You can't 'blow' a dome etc with too little power, apart from maybe sounding like s**t what damage can actually be done?
  7. Nimby
    Nimby
    Jan 27, 2004
    9,206
    +671
    An underpowered amp runs into trouble at high levels into difficult loads.
    The amp starts producing horrible waveforms full of distortion components which can overheat the driver voicecoils.
    This is not the same as turning an amplifier down.
  8. miceri
    miceri
    Apr 8, 2006
    1,048
    Stockholm
    +59
    Cheers :smashin:
    Driver voicecoils, don't often look under the hood of my amp, well, never if I'm being honest!
    But this sounds too technical for me. I'll take your word for it...
  9. SteveAS
    SteveAS
    Nov 3, 2006
    98
    Newbury
    +13
    Miceri, I think the voicecoils sit inside the speaker cabinets, not the amp itself.;)
  10. miceri
    miceri
    Apr 8, 2006
    1,048
    Stockholm
    +59
    I'll get me coat...
