a prize for the most basic question ever?
zico martin
But the batteries are running out of my Sky+ remote control and I cant work out how to get the back off to swap them!
:blush: :blush:
Starburst
Hold the remote upside down and the back facing you in your left hand (if you are right handed). The hinge is in the middle of the remote so you need to put pressure on the remote below the middle edge of the cover and press down on the catch at the top while pulling it towards you.
Yes they are a :censored:
FRANTIC FRANC
I advise my customers to use a house key to push down on the slot appling pressure to the direction the arrow is pointing. You should find that quite easy.
Cheers, Franc
