A potential Tosh XS32 problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by nunew33, Oct 14, 2004.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    For the 3rd time now Ive made a recording from AV2 and the sound has come from the tuner!
    I record twice daily as a minimum from AV2 so the channel is nomally set to this. But it uses sat control for channel switching.
    But last night i noticed that even though the last prorammed recording was AV2 the display stated Channel 3, which was where the sound recorded from. Normally after a recording the display states the channel it recorded from.
    You could argue that 3 bad recordings from 150 isnt bad, but it simply shouldnt happen. Just once it happened when I was about to time slip where I could see the image from AV2 but the sound was from the tuner. I had to cycle through "Input select" to get the sound.
    because I cant make it happen I havent figured out the cause.
    Am I missing a fundamental sound setting. (as far as im aware Audio button only affects sound output). The sound recording setting is dictated by compatability mode which is always set to (I).
    hs any other owner come across this "feature"?
  2. monocrider
    monocrider
    I had this happen for the first time yesterday albeit that I was watching TV through the XS32 rather than recording. I pressed Input Select to change to AV2 and although the picture changed OK the sound stayed with the tuner output.
    Using the channel up/down buttons to cycle through the channels then on to AV2 cleared the problem and so far I haven't been able to recreate it.
    Odd fault, and as you say it shouldn't happen.
    I'll see if mine does it again and if there is a reliable way to recreate it.
    Regards,
    John
  3. Dark Eyes
    Dark Eyes
    Jun 4, 2004
    127
    I have had this happen once so far (in 4 months usage), doing a Timer recording from 'Sat Control' freeview box.
    Thankfully the programme was repeated a couple of weeks later, but it does worry me that it might happen again on something 'more important'.
  4. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    something to monitor i think!!!
