A player just for dvds ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by spocktra, Apr 21, 2005.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    I want to replace a very average toshiba 340e.I dont need it to play cds or divx encoded stuff,dont need hdmi.Purely yuv connection.Sound not important as i mainly use headphones.Budget up to £350.Will consider second hand if need be.Any suggestion welcome.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Harman Kardon DVD22 is very good and can be had for under £200.
  3. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Thanks for reply.Have found it from pixmania for £170.Might try a demo first.
  4. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,426
    Yeovil
    +218
    If you mainly use headphones why not get yourself a pair of medusa 5.1 headphones. They are dirt cheap at about £35 and perform very well. You'll need a dvd player with 5.1 preouts. My suggestion would be the Limit 900SE at play.com for £80.
