A Muppet Bought a RDXS32!
Discussion in 'Blu-ray & DVD Players & Recorders' started by ricko, Sep 9, 2004.
  1. ricko
    ricko
    Dec 10, 2003
    11
    I hope you can help!
    After far too long surfing these fantastic forums I have bought a Sony Digital TV (model DX200U) which has freeview incoroprated and I have just bought a RDXS32. The problem I have is recieving the digital TV pictures via the DVD recorder. The picture quality via digital is far superior and I want to be able to record from this source. I would really appreciate your help with this, as it is driving me mad, but almost probably a simple solution.
    Cheers in advance
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    isnt it simply a case of setting source as Av1. And ensuring the Scart socket on TV is 2 way
    Wont be RGB though
