A-Mount Macro Lens SOS
Discussion in 'Photography Forums' started by Pirate!!, Jan 25, 2008.
  1. Pirate!!
    Pirate!!
    Mar 16, 2005
    7,736
    Liverpool
    +1,217
    Ahoy!
    Darned if I can get my hands on a dedicated 1:1 macro without adapter extension or better (2:1, 3:1 etc).
    Sigma 70-300mm is OK @ 1:2, but at distance.
    Anyone not using their dedicated macro lens can drop me a line. I promise I won't sell it!
  2. Brammers
    Brammers
    Feb 27, 2007
    852
    43
    +150
    2 options.
    1: Get some extension tubes. Loads go new for £50 on ebay, or you you could get the Aico set from here for £40:
    http://www.mifsuds.com/usedpriceindex.htm
    look under independant fit minolta.
    2: Rent a macro lens from http://www.photostore-uk.com/ You need to become a member first. They should have the 50 2.8, 50 3.5, a selection of 100 2.8s and maybe even the 200 4. I'd go with one of the modern 100s.
  3. Brammers
    Brammers
    Feb 27, 2007
    852
    43
    +150
    Oh, a 3rd option - buy a close-up adapter. Never looked into these so you'll have to get someone else to do your research I'm afraid :p
  4. Ikki
    Ikki
    Feb 23, 2004
    1,174
    2
    67
    Lancs
    +95
    There are always A-mount macro lenses available on ebay. :)
  5. Pirate!!
    Pirate!!
    Mar 16, 2005
    7,736
    Liverpool
    +1,217
    Agreed, but generally not true macro 1:1 or better, and certainly not in my price range . . hence the question.
  6. Ikki
    Ikki
    Feb 23, 2004
    1,174
    2
    67
    Lancs
    +95
    I don't know what your price range is but unless you are lucky you won't get a true 1:1 macro lens in the A mount for much under £150 new or second hand anywhere, they are quickly snapped up on ebay.
    I have to disagree that macro lenses sold on ebay are generally not true 1:1 lenses. The commonly seen Sigma 105mm, Tamron 90mm and Minolta/Sony 100mm lenses along with their 50mm versions are all true 1:1 macro lenses. If you want anything with greater than 1:1 then there is only one choice, the Minolta AF 3x-1x 1.7-2.8 Macro and that is both rare and expensive.
