A long cable to the plasma
Discussion in 'Plasma TVs Forum' started by DEO, Apr 22, 2003.
  1. DEO
    DEO
    Good Morning:
    I plan to place all my AV equipment (Denon A1 / Pioneer 656 / X-Box / Sky + etc.) on the other side of the lounge from the 50" Plasma.
    This means the cable length will be about 28 feet. Are there major issues I need to consider here?
    Dave
  2. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    I have similar length cables and I did not notice any degredation in quality over the shorter length cables I was using for a bit before I installed it properly.
    I would suggest you just ensure you get decent quality cables and if possible seperate your power cable from the other cables (although mine is not seperated, and again I notice no problems).
    For VGA cable I had trouble finding one long enough but in the end found a decent shielded cable somewhere on-line.
    For other cables I got custom length Lektropacks prolink cables.
  3. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    No problem for VGA and component, however I'd be careful with svideo > 6m, even with a good quality cable.
  4. DEO
    DEO
    Thanks guys: what about RGB connections etc.
