A little risky perhaps?
Discussion in 'LCD & LED LCD TVs' started by akki007, Jul 25, 2005.
  1. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    I have a 15" LCD
    I have a wardrobe
    I want to fix the LCD to the wardrobe door!
    There will be a way around cabling etc im sure. Any thoughts???
    :rolleyes:
  2. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    Make sure the wardrobe wood is strong.
    :rotfl:
  3. benwong
    benwong
    Make sure you mount the thing very securely, and don't slam the door shut ;)
    Ben
  4. igauk
    igauk
    Apr 8, 2005
    132
    Glasgow
    +6
    Make sure the weight of the TV doesn't pull the wardrobe over when you open the door! A few bricks in the bottom mightn't be a bad idea! Anyway, run the cables up the back,along the inside, make sure you leave a big loop of cable at the door jamb and then through the back of the door to the TV, easy! (I presume it's a hinged wardrobe door and not a sliding one). :D
  5. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    So in general we think it could be done? It's the only space i've got to put it as its a loft room!
