A little imagination required for a diy job
Discussion in 'General Chat' started by soupdragon, May 4, 2016.
  1. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    I'm a bit stumped as to how to finish a diy fitted wardrobe. I basically took 6 ikea wardrobe carcasses, did a bit of chopping and got as far as you can see in the pictures. The sloping ceiling made the job quite difficult and in hindsight, I should have got a pro in.
    Panoramic pic of its current status (excuse the mess!)
    To give a bit of a finish, I need a top border to run along the top edge along all of the wardrobes.
    You can see below where I put a little border to start with but I don't think that'll work...
    Other side and as you can see, tricky angles to work with due to sloped ceiling.
    It's getting on 2 years now so the missus wants it finished. Problem is, I really don't know how....help me please! :)
  2. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    Can you not pin some thin skirting board as a border?
  3. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    Not a bad idea actually...that could work, just a simple tapered shape. Getting a colour match might be difficult though, or maybe I should go with a contrasting colour.
  4. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    Possibly paint it the same colour as the ceiling to avoid having to match the wood.
    Matt White would probably not draw the eye too much.
  5. DJT75
    DJT75
    May 6, 2005
    10,647
    +3,610
    Can't you hide everything behind floor to ceiling doors? Cut to size
  6. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    That could work actually, especially as all our doors are oak coloured too, with white architrave.
    If I get the same sort of shape, maybe a 4 inch version, it might tie in together quite well :)
  7. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    Go for it buddy, think we have a plan [emoji1]
  8. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    I think I will you know, good idea so thanks for that :cool:
  9. balidey
    balidey
    Jan 2, 2009
    3,664
    +3,532
    Women! If we say we are going to do something, we will. There's no need to hassle us about it every 2 years.
    Only thing I could add is, rather then a slim finisher, you could go the other way, build a plinth all the way round about 5 or 6" deep and install lights behind so it lights up the wardrobes.
    • Funny Funny x 2
    • Like Like x 1
    • List
  10. blue max
    blue max
    Apr 12, 2006
    12,813
    London
    +4,219
    Like your architrave - very modern. Did you buy it or make it?
  11. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    I do like the idea of lighting, and actually considered lower plinth lights while I was putting it all together. The middle section is actually a dresser and although you probably can't see, there are 3 motion sensing LED strips which light up and with spotlights in the ceiling, I think I'll need to keep the rest simple. To be fair, if I went with more lighting, it would probably take me another 2 years :)
    We built the house June '14 and just specced the builder to install oak doors with white surrounds, with plain bevelled edge skirting. The actual overall bits n bobs he used for the door framing kit was something he chose himself.
  12. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    Sorry, only just seen this post. We did consider doors but the missus preferred open style.
  13. DJT75
    DJT75
    May 6, 2005
    10,647
    +3,610
    Sorry, I've just realised it's a walk-in wardrobe area
  14. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    So anyway, big thanks to hort for the white skirting idea, that's exactly what I've done.
    I'm half way through now so a quick update (In hindsight, this thread probably should have went in the diy thread that already exists, maybe a mod can merge?)
    I went with 69mm skirting, a chamfered edge like my existing skirting and it's already primed so just needs a lick of paint. The local diy place cut my boards to size for me and all in, was only 20 quid for the wood so a very cheap upgrade.
    As you can see, I decided to do both the top and bottom as I felt that would give a better overall finish, more tied in looking.
    Only problem was the board height, 69mm is too short at bottom, but next size up, 94mm was too tall. I went with 69mm and will pin it on as fortunately, the deep pile carpet will hide the height discrepancy.
    Just need to paint it now, plus use a bit of filler for the joins. I give myself about 6/10 for my joinery skills here but hoping the paint and filler will hide my sins :)
  15. paulyoung666
    paulyoung666
    May 4, 2006
    13,501
    Teesside
    +3,837
    Canny stuff , caulk the gaps though , don't use filler ;)
  16. DJT75
    DJT75
    May 6, 2005
    10,647
    +3,610
    Perfect solution
  17. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    Absolutely, got some decorators caulk, which is easy enough to work with. Just waiting for it to dry now and then just a final paint touch up :)
  18. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    I'm very happy with it so a big thanks to hort for the suggestion :)
  19. hort2074
    hort2074
    Apr 22, 2016
    1,095
    UK
    +311
    Call me Dan [emoji1]
    Looks fantastic, so different now. Very impressed.
    Look forward to seeing completed pics.
    And as somebody said, use decorators caulk rather than filler.
  20. busterbenny2001
    busterbenny2001
    Jan 13, 2008
    2,638
    Tavistock
    +1,923
    Love your doors and architrave, currently building a house, did you buy finished doors ? And was the architrave painted afterwards, lovely clean look.
  21. soupdragon
    soupdragon
    Jun 22, 2008
    8,609
    167
    Antrim NI
    +4,454
    Yes, the door were prefenished like the picture and architrave way painted. The joiner and following painter were both excellent, makes a world of difference when the finishing is pretty much flawless right throughout the house. I made sure to get the tradesmen a few boxes of beer when they were done :)
  22. busterbenny2001
    busterbenny2001
    Jan 13, 2008
    2,638
    Tavistock
    +1,923
    Thanks, im thinking of getting a carpenter to fit all doors rather than a general builder 16 or so doors i know,its now going to cost me a fortune in solid oak!!!!!
