A little help to required to make my wife happy.....
Discussion in 'General TV Discussions Forum' started by jfw, Jun 18, 2003.
  1. jfw
    jfw
    Dec 10, 2002
    25
    As I am sure all of you know keeping your partner happy makes for a decidedly easier life, therefore I am asking the esteemed members of this forum for a little help.......
    A bit of backgorund:
    I took delivery of a PF2 about a month ago and am generally delighted with it. However my wife is very upset that when she changes channels she hs to wait a couple of seconds. This is the result of the channel change being in the 2 digit format i.e. 01 for BBC1 etc. On old TV remotes there used to be a "-/--" button that let you toggle between 1 digit and 2 digits on the channel change. On the PF2 this is not there.
    My attempted remedies:
    1) phoned Toshiba Customer Service - thanked for advising of a problem they hadn't come across before - no help..
    2) Used old Tosh TV handset that had the button in question. This solved the problem until I switched off the set. One turning back on I was back to square one.
    3) tried looking in the TV menu but no reference
    What I am asking for:
    Does anyone have a solution to my very little problem ? Is the answer hidden away in the mystical service or designer menus ?
    Any help will make me look like a hero to my wife and for that I willl be eternally greatful.....
  2. scooby do
    scooby do
    Dec 11, 2002
    1,984
    48
    +83
    Sorry to state the obvious but does it not have P+ P- that can be used then hopefully you can disable channels not being used so they in theroy go around in a loop. Failing that then perhaps a learning remote could be used. I.E. set it to learn 1 then when it is receiving press 2 key strokes or store macros. Other than that cant reallty help.
  3. jfw
    jfw
    Dec 10, 2002
    25
    Scooby, thanks for the note........using the P+ P- keys not a problem with me but beyond the technical capabilites of my wife. Also there must be a better solution than going out and buying a learning remote !!
  4. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    You would think so.......but.....:confused:
