A little help please???
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jonah, Jun 20, 2002.
  1. Jonah
    Jonah
    Being new to this home cinema set up, I am looking for a few pointers if anyone can help.
    Four years ago I purchased a Kenwood SE-A750S hi-fi system.
    I am now looking to add a DVD player .
    Although the receiver (C-V350) is dolby pro logic, and has 6 channel input, how easy is it to add a DVD player and have Dolby Digital 5.1 sound.
    Are there any decent DVD players available with 5.1 decoder built in and 6 channel outputs. All the players I have seen so far only seem to have 2 channel outputs.
    Or, would it be better in the long term to bin my existing set up and buy a new receiver and amp altogether?
    Thanks in advance for all replies,
    Jonah.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    IMHO there are lot's of players with 6 channel output around, some have even DD and DTS decoding.
    Check out some dealers which carry several brands and it should be no problem to find a player which suits your needs in term of looks, features and - most important - performance.
    Perhaps a good idea and surely you will yield some improvement. And don't worry then if the player has a decoder or not, as long as it has a digital output (and all do have that) you will be fine; just ignore the decoder then (saves you some cabling, too).
  3. Jonah
    Jonah
    Cheers mate, thanks for the advice.
    What does IMHO mean by the way?
  4. Jase
    Jase
    Mar 16, 2001
    10,804
    United Kingdom
    +2,693
    In My Humble Opinion:)
