A little help /advice please PANASONIC NV-DS27
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by chloebean, Jul 5, 2005.
  1. chloebean
    chloebean
    Hi - i am new here so please bear with me...
    I have a PANASONIC NV-DS27 and i want to put video on my PC with it, which i cant at present as i dont seem to have the right leads to do it (and not sure whether i have compatible software?)
    I am tempted to sell it and buy something else? Is it worth doing that or should i stick with it? I want to edit on the computer really badly. Also the bit where you put a tape in, one of the cogs that turns it keeps coming loose/ comes off. It will cost a lot to fix, so as i say, am i better of getting a new one?
    Any advice / models you could recommend??
  2. Brian110507
    Brian110507
    In response to the first part of your question - it would help you if you read this thread :-
    http://www.avforums.com/forums/showthread.php?t=224902
    and the other threads identified within it.
    regarding the second bit - if cogs etc. are falling out of your camcorder it sounds like it's time for a replacement - what if the bit falls out while you are on a "once in a lifetime" trip and you lose all your video. read some of the many posts in this forum for suggestions for a new camcorder.
  3. chloebean
    chloebean
    Thanks -
    I knew firewire had something to do with it. I have a port for it on my camcorder, but cant seem to get a cable? where could i get one from? I have looked previously but cant seem to see anything?
    If i do cut my losses and get a new one, what do people recommend
