A Little Bit Strange
Discussion in 'Computer Components' started by walrustitty, Aug 15, 2013.
  1. walrustitty
    walrustitty
    Oct 19, 2010
    77
    11
    +3
    My rig will not restart (reboot) after the following Windows updates or any software updates No B S O D just blank screen no peep from speaker i have to Hard boot and then its OK it has never crashed while running it a bit of a pain because it is my HTPC and the timer recording go up the swanny if the daft thing update some soft automatically at night when am working WINDOWS update i do manually but as i said before it still will not start up again just wondering if anyone has had this problem my rig is
    ASUS M4 a88td-m evo
    8gb Corsair 133htz ram
    126gb San Disk SSD as O/S Windows 7 H P 64 Bit
    3 2tb WD Green HDDs
    AMD HD5670 Graphics Card
    Alpine 500watt PSU (i know is is CRAP but i am not O/C this PC
    I do think is WINDOWS based fault i did reinstall a bout 3 months ago and it didn't do it before
    any ideas:lease: folks
    thanks WALRUSTITTY
  2. maddogb
    maddogb
    Apr 11, 2009
    1,652
    63
    Cumbria
    +195
    try system restore, immediately turn off updates after, that should tell you if it is indeed the update causing it.
  3. walrustitty
    walrustitty
    Oct 19, 2010
    77
    11
    +3
    Thanks will do
