A little bit of help please
maldred2004
I have a WD hard drive that I use to store saved games from a previous Xbox. It’s not SSD but I’m still using it because it’s got 3TB. What I need help with is it’s a standard USB of which there is only one port on the front of the series x. My problem is if I use my steering wheel I can’t use my save games can anyone tell what the USB ports on the back are and what adapter do I need to convert??
many help would be appreciated
ta
adbailey18
Little confused, but have you tried the USB ports on the back?
I have a 2TB HDD which works from any USB on my SX.
Indiana Jones
ta
There are two USB ports on the rear of the console, just plug your drive into one of those.
maldred2004
Thanks everyone, now I feel like a bit of a pillock. When I initially set up the Xbox I tried about 6 times to input the usb, in my excitement I guess I was rushing a little and didn’t try hard enough. Thanks anyway if I hadn’t asked I would probably procrastinated for ages over it!!
Goooner
A USB hub will work fine too. I’ve got two external drives connected to my Series X via a hub and it all works fine.
65-inch LG C1 Review coming soon to AVForums
