A little advice please.......
Discussion in 'Home Cinema Building DIY' started by Pudding, Feb 25, 2014.
  1. Pudding
    Pudding
    Feb 23, 2014
    7
    4
    Ripon, North Yorkshire
    New here so please be gentle.
    Current system is 37" lg tv yamaha amp and b&w mt30 with pv 1 sw
    Would like to hang a tv (32"+) on a stud wall. Along with a floating shelf system for the amp, dvd, youview box and a games console.
    The mains socket is not where it needs to be and I would like to hide all the associated cabling that comes with a 5.1system.
    Don't really want to go down the route of creating a floating wall on top of the stud wall but would like to keep the wall as it is.
    My question is should I remove the plasterboard so I have enough access to put in some trunking and move (or run a spur) the 240v socket. Strengthen the studs so they can support a tv bracket and a floating shelf to support the amp etc.
    I would then replace with new plasterboard and probably have the whole wall skimmed
    Thanks in advance for your advice.
  2. 00Paul00
    00Paul00
    Apr 6, 2010
    580
    46
    Bristol
    +232
    Sounds like you've got it sussed to be honest!
    Make sure your new spur wiring confirms to regs. Get a sparky in if in any doubt.
  3. Pudding
    Pudding
    Feb 23, 2014
    7
    4
    Thanks just wanted to be sure will get a sparky to run the spur.
