A little advice needed
Discussion in 'Hi-Fi Stereo Speakers' started by rs1612, Jan 14, 2017.
  1. rs1612
    rs1612
    Jan 14, 2017
    17
    4
    Clacton-on-Sea
    Hi guys, first time posting on this forum!
    I recently purchased the Wharfedale Xarus 5000's for a really cheap price since the guy wanted rid of them quick. They are pretty outstanding, the bass on them is amazing, the mids are the best thing about them about them so much detail and bass in the mid section.
    I was thinking about getting an active subwoofer just to lower that frequency range a bit, as the speakers don't really go down that low in the bass section
    I wanted to know what your opinions of a good active subwoofer to pair with these speakers? Is it best to stick with Wharfedale make so they are similar sounding or is there another make that pair with wharfedale speakers well? I listen to many ranges of music, but my favorite is house/techno so I need a quick responding sub-woofer for all the bass lines haha!
    Any recommendations would be greatly appreciated guys
  2. rs1612
    rs1612
    Jan 14, 2017
    17
    4
    Clacton-on-Sea
    Sorry guys, posted in the wrong section, I have posted in the Subwoofer section! Not sure how to delete this thread.
  3. kc5819w
    kc5819w
    Dec 24, 2016
    200
    46
    +46
    Its not necessary to get a wharfdale sub, it wont be matched or similar to the speakers you have. That said, one of the most reasonable and well reviewed sub is the wharfdale SW150.
  4. High Fidelity
    High Fidelity
    Sep 1, 2007
    969
    64
    +283
    I have yet to find any sub that integrates properly especially for classical music and prefer TL speakers that have deep enough bass,
  5. rs1612
    rs1612
    Jan 14, 2017
    17
    4
    Clacton-on-Sea
    I actually have read up about the SW-150 .. Would that be worth it? I have seen them going for about £100 - £150 range.. I always prefer quality, would always be willing to spend a little extra IF it's worth it.
  6. kc5819w
    kc5819w
    Dec 24, 2016
    200
    46
    +46
    Dont know about many others, but i'm sure if you get a well reviewed one that fits your budget it will work well. The SW150 is a cheap model. It works fairly well, but there are better ones.
  7. Paul7777x
    Paul7777x
    Jul 23, 2016
    2,876
    North east. U.K.
    +1,007
    I'd go for a BK Electronics sub. They are sold with no middle man and are excellent value.
    Even the cheapest, the Gemini II is an excellent sub.
    Gemini
    I've owned two, still own one and they are as good as it gets at this price. The wharfedale is an 'adequate' cheap sub. Not a patch on the Gemini.
