A List of Software HD Players for the PC?
Discussion in 'General TV Discussions Forum' started by rogeralpine, Sep 1, 2004.
  1. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    Currently, I have;
    VLC - not very good on my setup - UPDATE - v 0.8.0 beta is much better folks. Previously clips that juddered now don't and AC3 pass-thru is easy!!
    Elecard - quite good, judders sometimes
    Windows Mediaplayer 9 (and above v10 beta out) - obviously best with WMHDV Cheers Mr151
    WinDVD6 - not yet tried this properly
    Zoomplayer - needs a fair bit of user input - Cheers Loafer316 Update bysireddie
    WMPClassic - Cheers zAndy1
    BSPLayer - Cheers cwick
    On Air HDTV USB Softwareplayer - Cheers Pietnoeck
    What else is out there folks worth giving a go? I'll probably give WinDVD6 a blast - but is there anything else?
    I'm still getting problems with no s/pdif passthru on HD stuff. I've got AC3filter installed as well, but all to no avail!!
    I'll update this entry with the new players ppl post info on. (I'll add the URL's as well - when I get round to it!)
  2. Loafer316
    Loafer316
    Apr 8, 2003
    330
    add Zoomplayer to that..i personally havn't figured out how to get the best out of it..but it lets you use the installed filters etc from the other players such as windvd and powerdvd or elecard to decode the .ts files or wmhdv
  3. zAndy1
    zAndy1
    Nov 26, 2002
    22,413
    2
    5
    163
    +8,811
    I installed media player classic last night and it seemed very good from what I saw, no stuttering and spdif passthrough for everything I played, haven't been able to get spdif passthrough working in Zoomplayer yet!
    Worth giving it a go, I was impressed with it..
    Cheers,
    Andy.
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Have had good results with BSPlayer (http://www.bsplayer.org/) in cases where VLC doesn't work - which seems to be more and more frequently :(
  5. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    I've used Zoomplayer b4 and although there's a wealth of options, I didn't particularly find that it had a user friendly interface.
    I'm d/l MPC as we speak Andy - let's see how it goes.
    Will have a look at bsplayer next cwick
    Anymore??
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    cwick,
    I downloaded BSPlayer and can get individual files to play, but not a whole movie. You can't seem to select all files and then open like you do with most players like zoom player etc.
    Am I missing something ?
    Jeff :rtfm:
  7. MR151
    MR151
    For .ts/tp files, I've tried 4-5 and find that WMP Classic is the easiest to use(for me) and IMO, has the best sound.
    Btw, I haven't dl it yet, but the official release version of WMP 10 is out now. Try it out and tell us if it can play .ts files.
    http://www.microsoft.com/windows/windowsmedia/mp10/default.aspx
  8. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    User Update:
    VLC seems to have the best controls (those that work) of those players I’ve used and the easiest Audio options to get AC3 out, but now I’ve had chance to sit down to watch some HD stuff, I find the “judders” are too noticeable and therefore my search for a decent player continues. Interestingly I played Sinbad and that didn’t appear to suffer with “judders” – Bourne Identity on the other hand appeared to suffer greatly, the reason for this I’m not certain – film against toon? I don’t know!.
    BSPlayer and Elecard players both appear to have better playback than VLC, but I can’t select any options to get AC3 out. Has anyone had any success with these 2? If I can get AC3 out, I will sit down and thoroughly test some HD stuff and see how they compare.
    MediaPlayerClassic – as Andy says above, this appears to be the best of the bunch so far, and playback seems to be “judderless” AC3 out I can get to work, but I have to ensure I run AC3filter 1st. If I mess around with any of the sound settings, I lose AC3 and it all goes to pot. The only downside to this program appears to be it’s inability to allow the user to pause, fast forward/rewind or select any point in the film. If I try any of these options, the film freezes and I can’t get it to play again without restarting. Anyone had similar probs with this program?
    WinDVD6 – I understand it’ll accept “ts” files and play them, but you have to rename them as a “tsp” file. Have yet to give this a try – has anyone got any comments on this program?
    Not ventured into Zoomplayer testing – didn’t have much luck b4, that was on a different PC, may give this a go.
    I have seen mentioned a need to possibly remove Fast Writes – you do this at boot up yes? Can someone just point me in the right direction? Also, I need to check whether my graphics card is set to AGPx8 – again, where is this checked/altered?
    Is there anything else worth mentioning that a user should look to change their PC settings in order to get the most out of it when playing back HiDef stuff?
  9. quig
    quig
    Jan 17, 2004
    20
    Have you turned the deinterlacing on? This would explain why 720p material doesn't suffer as 1080i does.
    However, VLC seems to be the only player that will do this, so material that won't play in VLC unfortunately can't be deinterlaced in players that will.
  10. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    Ahh - sounds good!! I've booted up VLC - can you point me to the option - all I can find under the main headings for Video is a Deinterlace menu that has selections for one of the following,
    Disable
    Blend
    Bob
    Discard
    Linear
    and Mean.
    And then under the preferences menu - selecting the Video option, I've ticked the video deinterlacing filter to being on, I've yet to see if that resolves the problem, but I'll have to wait until I put my PJ on later to check it out properly.
    Welcome to the forums btw!!
  11. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Oops. Missed that. I just use the playlist (right-click to bring up the context menu), and just drag files in from an explorer window.
  12. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    I found VLC to b too juddery regardless of settings.
    I dl'd MPC last night and stil find things juddery even with reclock.
    However its not all that simple.
    Charlies Angels 2 (1080i .ts) plays silky smooth . On bob it looks fine ( apart from the bob artifacts) on weave it looks as if MPC can't deal with 3:2 pulldown as you see the "hairy" pulldown frames. If I play other 1080i material on it (ROTK 1080i) it judders regardless of the deinterlace .720p on the other hand seems to play with only small judders ( more like 3:2 pulldown judder which is acceptable).
    Looking at the stats I'm getting 0 dropped frames so the judder is either down to a bad encode , a cadence muck up on the original material ( same thing probably) , or the fact I'm running at 56Hz into a sony HS20 which wouldn't explain why NTSC dvds are way smoother and Charlies Angels plays just dandy.
    I'm hoping that when Theatertek 2 comes out it will solve a lot of these problems ( at least play 1080i as smoothly as it plays 480i)
  13. pietnoeck
    pietnoeck
    Nov 23, 2003
    118
    16
    Flanders Fields
  14. Baggy
    Baggy
    Jan 25, 2002
    1,143
    63
    Burton-on-Trent
    +152
    Thanks for the link.
    I've just tried this player and it seems quite good.
    Only tried it on a few clips and it got rid of the stuttering for me.
  15. sireddie
    sireddie
    Just a tip:
    If you have jidder probs playing Hi-def material, try using Zoomplayer and change "Player Thread Priority" in "Advanced Options -> Values & Tools -> Other" to "Above Normal".
    This has made it possible for me to play almost all content (even 1080i) whithout dropped frames on my AMDXP 1800+/768 PC2100/GeForce3 Ti200.
    Before I tried this I hade pretty jiddery playback on a few clips, but now these play just fine.
    Note that your computer will seem slower/less responsive when using this option. This is because of ZP will have higher priorety than the rest of your programs/processes running (at least most of them).
  16. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    Good tip - I've yet to give Zp another go.
    VLC new beta 0.8.0 is out and I can confirm it plays MUCH better that release 0.7.x. Well worth giving it a go if you had trouble before.
