A goog Hidef Mpeg 2 TS decoder card?
Discussion in 'Televisions' started by Bob Todd, Dec 28, 2004.
  1. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    does anyone know of a good Decoder card that will decode and play High def TS streams from my TV while keeping the CPU load low?
  2. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,438
    48
    +64
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    sounds great any uk sellers?
  4. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,438
    48
    +64
    The website that I linked to, Digital Connection, will ship to the UK. The shipping rate is very reasonable. I think it only costs about £15 delivery.
  5. Yaka
    Yaka
    Dec 20, 2000
    1,675
    2
    63
    +113
    its not clear if you need the the aditional board in order to connect to a dvi/hdmi based screen
  6. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,438
    48
    +64
    Yes, you do need the additional board - I have one!
    This connects directly to your display and has nothing to do with your graphics card incidentally.
  7. Yaka
    Yaka
    Dec 20, 2000
    1,675
    2
    63
    +113
    very tempting
    im looking to get an LCD tv soon will this let me use my pc as a dvd player and use the full resulotion of the screen?
  8. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    yeah mat it works alot like the sigma xcard I had for Playing movies, however I would be looking to dual output to the screen, using my gfx to connect to the DVI of my sharp GA3 to use for PC work, while outputting from the MYHD to a component switch box, I know DVI has a better PQ, 8 feet away from a 32 inch screen, its benefits arnt that noticeable, also the Sharp Tv's have a problem with 1080i via DVI not via component
  9. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,438
    48
    +64
    The MyHD card will happily output component - and it looks excellent!
  10. pietnoeck
    pietnoeck
    Nov 23, 2003
    118
    16
    Flanders Fields
    But does it do 1080i at 50 hz ? And will it be able to capture satellite stream from european HD satellite .
    I inquired about the Fusion card and they said it only worked with american satellite broadcats.
  11. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    I thought the Fusion was an ATSC 8-VSB receiver for use with american terrestrial digital, rather than US digital satellite systems?
    For the Euro1080/HD1 HDTV broadcasts in Europe you need a DVB-S card - and also some means of decrypting. You can get a Technotrend or Hauppauge Nova-S budget with separate CI slot to mount a CAM (Conditional Access Module). This will allow you to receive - but doesn't output an HD signal.
    For this you could use an ATI Radeon with Powerstrip or try to find a 1080/50i capable output card (haven't come across these. The XCard will output HD but only from a 576/50i source)
  12. pietnoeck
    pietnoeck
    Nov 23, 2003
    118
    16
    Flanders Fields
    HI,
    That is about my setup.
    My point was that , as the Fusion, the MyHD card is also a capturecard for HD.
    Something you won't be able to use overhere
