a good pci card?
Discussion in 'Desktop & Laptop Computers Forum' started by watchinthewheel, Apr 29, 2005.
  1. watchinthewheel
    watchinthewheel
    i have decided to try and connect my pc and ntl set top box together so i can watch and record tv. im not planning on sending the recodings back to a tv though, my monitor is far far better quality. what im looking for is a decent pci card that will let me watch and record. im looking at an s-video one if possible, i know rgb is better but the sweetspot card is far too expensive concidering what i want it for. also is it as simple as getting a scart-s-video converter cable and plugging it into my pc capture card?
    thanks for any advice or replies.
  2. lisag
    lisag
    Jul 14, 2004
    6,007
    Essex
    +398
    I had a Pinnacle PCTV Stereo which worked very nicely with Dscaler. I imagine a scart to svideo adaptor will work, does your set top box not have s-video out?
  3. watchinthewheel
    watchinthewheel
    i dont think it does but im not sure tbh, i assumed none of em did, ill have a look.
    im assuming dscaler is a recording app? thanks for the reccomendations,m i just wanted a name of a card that someone had tried and was decent quality, ill get that one, thanks a lot for the reply.
  4. watchinthewheel
    watchinthewheel
    bump, any other pci card i should concider?
