a good coaxial cable
Discussion in 'Cables & Switches' started by keyser, Jul 10, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Can anyone recommend a very good coaxial digital cable to connect my dvd to my amp, it has to be 1,5m - 2,0m, and where I can order it. I have a pretty cheap vivanco one that I bought at a supermarket and it just doesn´t look that convincing to me.
  2. Stewart C
    Stewart C
    I bought Ecosse Reference digital coaxial and it sings like never before.
    Prices range from £20 - £150 per metre
    Regards
  3. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Thanks. Do you know where I can get it, I don´t live in the U.K. so an internet order would be good, or some well known store. Are they available in longer than 1m... i HAVE TO have 1,5m-2,0m. Why is it that coax cables always come so short but optical doesn´t.
  4. Chucky
    Chucky
    I believe it has to do with the laws of physics and the design of coaxial cables. The further the signal goes, the weaker it gets. If you had a coaxial cable of about 50 metres, you would probably get almost no signal on the other end. Thats because the actual wire absobrs it all.
    Optical is different because the light pulses can travel much faster, further and not get absorbed by anything at all.
  5. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Keyser,
    2 metres is no problem for a decent digital coax cable.
    As long as it is well terminated and uses good 75 Ohm cable, you will be OK.
    Mark.
