A FEW SPEAKER & SUB QUESTIONS.....(REL , MORDAUNT-SHORT)
Discussion in 'Home Cinema Speakers' started by istari knight, Jun 25, 2005.
  1. istari knight
    istari knight
    Feb 18, 2005
    61
    11
    Falmouth
    just a few questions really....... firstly,
    Ive just bought a REL Q50 but haven't received it yet(got it off eBay)
    i would like to know the dimensions of it if poss ?
    And i am looking for any info / or a data sheet etc.... on some Mordaunt-Short MS815 speakers...
    thanks for all & any help !!!
    :thumbsup:
  2. Beobloke
    Beobloke
    Aug 10, 2004
    1,312
    Out in the Sticks!
    +65
    Well, i've had a rummage throught the archives and found the following information about the MS815's for you -
    90dB Sensitivity
    8 ohms nominal
    Frequency Response 45Hz-22kHz
    Recommended amplifier power rating 15-150W RMS
    Bass Driver - 240 x 160mm elliptical
    Midrange Driver - 190 x 130mm Elliptical
    Tweeter - 25mm ferrofluid-cooled gold anodised aluminium dome
    Second order crossover on bass, first order on midrange and treble.
    Bi-wireable
    Dimensions - 950mm(H) x 204mm(W) x 329mm(D).
    Internal volume - 44 litres
    Weight - 15.0kg per speaker.
    Photo attached shows the 815 (on the left) and the 816 (on the right)
    Hope this helps!
