A few questions since Sky+ installed
Discussion in 'Sky Digital TV Forum' started by Spooky, Jul 24, 2005.
  1. Spooky
    Spooky
    Dec 11, 2002
    762
    46
    Scotland
    +123
    A few observations I have found since I have had Sky+ that I would like to find out if this is normal.
    Is the picture softer than normal Sky, gotta say on my humble system its far softer.
    Are the recordings from Sky compressed? Seems to be a fair bit of compression from Sky One recordings etc, is this adjustable ie best quality may take more room but would defo be worth it.
    And lastly, I would have thought the software on Sky+ would have been at least the same as my Sky box but there is no option for removing the red Dot, whats the latest software for a Pace V1 box?
    Thanks in advance
    Spooks
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Is the box set to output RGB as, if it's set to PAL, it may make the picture look softer?
    The box records the bitstream as it is transmitted so the compression on the recording is identical to the compression used for the broadcast so there is no way to change it.
    The Sky+ boxes get a different software download to the standard digiboxes and, AFAIK, haven't got the red dot removal feature yet - at least mine hasn't.
    HTH
    John
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,608
    2
    In a secret location with Jennifer Lawrence
    +9,316
    It's annoying about the red dot during live viewing, but it doesn't appear when you watch back a recording though.
  4. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Same here - why can't I set the red dot to disappear ass I could before getting upgrade to Pace 3000 box. Done a forceware upgrade...no difference. Can someone advise please?
    Thanks.
  5. ctcrm
    ctcrm
    May 6, 2003
    134
    my sky + box fitted last week times the red dot out.
    i have to say though the picture qual is far better than i had anticipated on live or recorded
  6. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    The picture quality is subjective and is largely dependent on your choice of TV set. Some TV sets make a real mess of the Digibox picture.
