M
mridley
I've just upgraded my Sony amp to a Denon 2802, I have a few questions;
1. Is there anyway to get the on screen menu without having to manualy select it via the TV remotes? I currently have it connected via an svhs to scart but have to switch to AV2 on the tv remote.
2. I have connected the fronts to the sub which in turn is connected to the amp, if I connect the amp just by using an rca cable the bass sound is very weak, is this right ?
3. Can't quite get my head around NEO 6 or Matrix, do these two only apply if you have the extra rear speaker?
Thanks in advance
Thanks in advance
