A few questions about the Sony HD5.
Discussion in 'Headphones, Earphones & Portable Music' started by L11, Jun 3, 2005.
  1. L11
    L11
    Jun 2, 2005
    323
    +7
    When I change tracks on my HD5, i can feel the hard drive 'moving', is it supposed to this?
    Is there away to shuffle through artists (eg, shuffle all michael jacksons songs, through all albums)? I really don't understand this unit mode
    Thanx in advance
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Don't worry, that's normal. It's a result of there being not very much space between the outer casing and the drive (it's a tiny unit). You'll be able to feel the hard drive rumble a little. Sony confirms this in the manual.
  3. myepitome
    myepitome
    Yea, that's normal for most hdd players, at the end of the day its amazing they can fit such a tiny hd and have a removable battery!
  4. myepitome
    myepitome
    Right, for this you need to turn unit on and shuffle tracks (im not sure what shuffle items is...) and then select Michael Jackson and press play and it should shuffle through all the albums
  5. myepitome
    myepitome
    Just read about "Shuffle Items" and that basically shuffles the tracks in one album of that artist, then shuffles the tracks in the same artist's next album, so you definitely want shuffle tracks
  6. Simebaby
    Simebaby
    Sep 17, 2004
    736
    I thought it was the opposite... it plays the albums (or artists if you start with genre) in random order, but the tracks are played in the correct order.
  7. L11
    L11
    Jun 2, 2005
    323
    +7
    Also, sonicstage doesnt wanna convert any of my wma files while transferring. it jus says 'these files cannot be played back on this device'.. and when i convert them manually to atrac3 or atrac3plus, and then try to transfer.. it still doesnt work
  8. myepitome
    myepitome
    shuffle items - shuffles the songs within an album, not within the artist
    but if u turn on shuffle tracks and then when you reach the artist in the list, press play and it shuffles between however many albums that artist has
  9. Chox1988
    Chox1988
    Mar 30, 2005
    16,824
    basingstoke
    +9,280
    try converting them to mp3 using third party software first. then try atrac3plus.
