A Few Questions About The Qnap 209
Discussion in 'Playstation Forums' started by DenzilTK421, Feb 2, 2009.
  1. DenzilTK421
    DenzilTK421
    Nov 6, 2005
    838
    +38
    Dear All
    I am think of getting a Qnap 209 NAS.
    Primarily it will be used to serve songs and videos to the PS3 & MacBook.
    The questions I have are;
    1) Will I be able to backup the MacBook directly to the 209?
    2) Will I be able to backup the PS3 directly to the 209?
    3) Will I be able to move my PlayTV recordings (and any other file for that matter) from the PS3's menu system to the 209 & will these remain playable from there (or will they have to be moved back)?
    4) Will the MacBook treat any file on the 209 like it would if using a USB attached HDD (will it read write directly, or is it more like a ftp type set up)?
    I can't think of any more questions, but please give me an outline of your experiences with a similar setup.
    Thanks in advance.
    Denny
  2. DenzilTK421
    DenzilTK421
    Nov 6, 2005
    838
    +38
    i hate to bump - but anyone :lease:
  3. Jamie
    Jamie
    Jun 27, 2007
    5,320
    2
    Harrogate
    +1,379
    Yes you should be able to do this.
    No, you need a directly attached USB drive/pendrive to backup the PS3
    No not directly. The PS3 sees the streaming media server on the QNAP, it doesn't see the NAS as a drive. you can copy stuff from the NAS to the PS3 but not the other way round. I believe if you copy the files via an external disc to the QNAP then they should play from there
    Yes you will be able to use the NAS just like a normal drive on the Mac
