jlcrawford
I have my PC built and working but the wife hates it and I want to make it user friendly so some help would be most appreciated.
My system is using Rad 7500, P4, H3D and Maudio sound board and I would also like the flexibility of using the PC as a player if needed.I have dvd players and also a Denon receiver also in thensystem.
MyQuestions
I wish to configure for using a Pronto to control everything and to add a digi tv card, what is the best way/software to do it via remote control-preferably using my wireless keyboard or Keyspan receiver.
I tried MyHTPC but havent got it to load the likes of H3D software- can it be done
What horizontal and vertical frequencies are recommended for 1280x720p on a 16:9 screen.
Are there other front end software packages like MY HTPC which offer system integration?
Basically how do you control your HTPC?
MyQuestions
