A dumb question...(possibly)
Discussion in 'Projectors, Screens & Video Processors' started by Juzminator, Jun 26, 2002.
  1. Juzminator
    Juzminator
    Mar 28, 2001
    346
    Ipswich,England
    Hi guys,
    I'm very tentatively looking into getting a PJ (probably the much-discussed AE100), and I was wondering this:
    You know that "stuttering/jerky"effect you get on R1 DVD's when there's a long, slow pan (sorry - I used to know the actual technical term for this, but it's gone outta my head at the moment)? Will having a PJ remove it?
    I'd be feeding the PJ from my DV737 (in progressive mode/component cables??).
    Sorry to be a bit vague, and apologies if this has come up before, but as I didn't now the actual term used I couldn't very easily do a search :blush:
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    No it wont remove it. It's there because of the method used to turn 24 frames per second film in to 60 fields per second video. The only way to rty and eliminate it is to re-constitute the original 24 frames and then show them in multiples of 24 refreshes...ie 48Hz, 72Hz. There are video processors and HTPC's that do this but there are very few fixed pixel projectors that will work at these refresh rates.....no problem for crt's(of high enough bandwidth) though....
    Gordon
    It's called judder...or stutter...or annoying...
  3. Juzminator
    Juzminator
    Mar 28, 2001
    346
    Ipswich,England
    Thanks Gordon :)
    Bit PO'd that a PJ (hee hee) won't remove this niggling dislike of mine....
    Never mind.
